Das_Wookie
- Jan 11, 2008
- Austin, TX
What would folks recommend as their preferred best sources of information for someone who was just getting started out with machining (Milling and Lathe operations) who wanted to become proficient as a machinist, but who don't have regular or ready access to an instructor?
I'm very efficient as Self Teaching, and know using this method I'm going to make mistakes that are going to most likely lead to Learning Thing$ the Hard Way(tm) (I've already most likely ruined a brand new HSS 3/4" endmill due to too experimentation which resulted in finding WAY too high of an RPM which put a gouge in it, Doh!) but one way or another... I intend to learn how to become a decent machinist. I've got a 1969 variable speed 1.5HP Bridgeport, a 1943 Monarch CK Lathe, and a Jet 9x20 Lathe. The Monarh isn't presently running, and I'm in the process of restoring it using the Jet 9x20 and Bridgeport to manufacture parts (as well as casting ala Gingery green sand aluminum and a propane powered foundry).
I've picked up a few books, with the general idea that the older, the better. I've got a 1941 copy of Audels Machists as well as a few other select texts, but not quite what I think I need which is more something akin to an instructional book to get someone up to speed on being a journeyman Machinist. I've heard about and purchase (yet not yet received) about the old Henry Ford "Shop Theory" text, which I'm hopeful will get me going more in the right direction there.
I've also tried to found some videos like the Darrell Holland "Professional Machine Shop" series, as well as the MIT Machine Shop Skills... and skulked about YouTube and found some interesting folks (MrPete222 / Tubalcain) who have some excellent series sharing their info. These have been tremendously helpful, tho I'm sure there is still tons more out there that I'm missing out on.
This hunting around at random almost guarantees however that I'll only find something by chance, and if there is something I Really Must Find I won't know about it unless I'm told... so, if YOU had to do it all over again, or if YOU had some nugget of knowledge you felt invaluable for a n0ob to study and learn from, what would that be?
Lastly, what sort of Project would make a good one (or ones) for making sure I HAVE to learn all this stuff and put it to use? One would think this is the sort of thing I'd have learned in High School, in a shop class, but by the time I got there shop class had been for the most part dismantled by the fear mongers, and while we did have some of the equipment still, it sat, collecting dust, unplugged, and verbotten for us to go anywhere near... so now, I have to ask strangers on the internet to be my shop teacher.
