Bill D
- Apr 1, 2004
- Modesto, CA USA
Off Topic: I am installing a split ac in my house. I need to run the refridgerent lines about 20 feet down one side of the house. Plan is to run a 3"( or maybe as small as 2" if I can fit it) in conduit with the low pressure line insulated and the power wires inside the same conduit. So shoud I put the high pressure line inside the insulated bundle or leave it in free air so it does not heat the return line to the pump.
Normally the high pressure line is left uninsulated so it can shed heat to the air. If I bundle both lines together it will warm the return flow and that will raise pump temps.
Also how far apart can I have supports of 3" ridgid conduit?
Bill D.
Modesto, Ca often over 100 in summer
Bill D.
