Greenworks
- Feb 1, 2017
Hi all,
I've been mostly turning stuff, but my lathe has live tool capabilities. I've got turning somewhat down for a self taught novice, but I've got some questions about milling. I know this topic has probably been covered half a million times on this forum, and I tried search with little success. What are some rules of thumb for slot milling? I've got an open ended slot that I'm needing to make with a 0.0625" ball nose endmill with a final depth of 0.225". the slot width is .0625". Material is 6061 T6 aluminum. What is the DOC for stepping down into a slot based on? Percentage of the tool width probably? Feeds and speeds would all stay the same right? For regular milling what percentage of the tool width axially would you use for a regular cut that's full depth? I know nothings hard and fast, but there has to be guidelines. The Machinist's Handbook laid it all out perfectly in engineer gibberish that was completely unintelligible without a for dummies translation.
Thanks all in advance
