jarhead jim
- Apr 28, 2009
- Bartley,NE
I have a set of 3/4" toolholders that take the TCMT 32.5 inserts. I believe the holders are import. Of course the inserts are cheap, crappy pieces of sh-- and I'd like to get some quality inserts. My question is.....what make would you guys recomend? I found some Iscar, Sandvik, Kennametal, etc. but the numbers following TCMT is 3(2.5)1 or 2. Is this the same as 32.5? Another question I have is.....There are 2 different makes I'm looking at and the numbers and letters following the TCMT ( I know what the letters TCMT stands for) are confusing. What do they all stand for?
Sandvik 32.51 UR 4025
Sandvik 32.51-MM/16T304-MM 2025
Kennametal 3(2.5)0-LF16T302-LF
Would any of the above fit my toolholders and are they the right type of steel/carbide? I'm used to using the rocker style on my lathe so this is all French to me.
I'm going to be using the inserts on grade 8 to regular steel.
Thanks!
Jim
Thanks!
Jim
