Small homemade portable line boring tool
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Aug 2007
    central wisconsin
    68
    Default Small homemade portable line boring tool
    Has anyone built or have an idea of how to build a small (3" bore and under) portable line boring tool. I'm rebuilding an old Ford backhoe and the boom pivot pins need work. Someone did a poor repair job and installed overrsize pins with no bushings. This backhoe is for playing around on my land not commercial use, so I wound like to do it has cheaply has possible. I know there are people that do this in my area but they get big bucks to come out and do it. I also have seen Earl Hanson's website, but his info and instructions cost alot. Has anyone ever purchased his books or CDs? Is it worth the money?? I know if I saw one setup and operated I could make my own. Any thoughts...
    Oct 2006
    Klamath Falls, Oregon
    3,467
    355
    864
    I'd make a couple of match bored plates to tack onto either side, then make a boring bar to fit inside. You'll have to stand them off enough to get the cutter inside there and adjust it. Just a rough idea for you.
    Oct 2005
    erie,pa
    8,984
    16029
    4553
    Line Boring Book, DVD and Plans ???
    Kinda hashed it over pretty good awhile ago.
    Aug 2006
    Hesperia, SoCal
    4,369
    987
    627
    ....and more here...
    Line Boring in the field
    Bob
    Aug 2007
    central wisconsin
    68
    Thanks for the links to the threads guys, but I had already did a search on this and read those threads. My opinion is they briefly touched on the tooling and setup and mostly told about how it was a tough line of work to be in. Also most of it was larger bore line boring 6" and bigger with 1.5"-2" bars. I'm looking for a smaller scale setup under 3". Any pictures videos and explainations would be great. I kind of understand that basically your just centering a bearing on each end of the bores and running a boring bar through it.
    Oct 2008
    Indiana
    185
    I don't have any info as to make your own but if you go to www.youtube.com and search "York 4-14ET line boring Machine" you'll find an actual commercial one in use and the setup used to center the machine. It's not "build your own" of course but it will give a good idea of exactly what it takes. Hope this helps.
    Aug 2007
    central wisconsin
    68
    Hey PlantationPete, That Utube video cleared up alot of things for me and was exactally what I was looking for. Thanks!!
    May 2008
    elmirage ca
    483
    27
    Default boring
    Other option is to rent one from climax
    jim
    Apr 2007
    Melbourne Australia
    1,262
    9
    10
    I can not see a backhoe pivot pins needing precision alignment, if they are anything like my forklift mast pivots. I just machined some new bushes and pins and used a die grinder to clean up the un bushed bores till the over sized pin had good bearing. If the machine is not in commercial service and your pins have a grease nipple which is used to lubricate them regularly then they should give good service.
    FWIW I made line boring bar for machining some engine mains but I used a mill to supply the feed and rotation, while the bar ran in bronze bushes.
    Oct 2008
    Indiana
    185
    I had similar questions about portable line boring some time back and talked to a guy doing some fab work for our company who had one and told me about the video. I don't have any need for one but would sure like to have one lying around to play with. Glad I could help
  11. #11
    Jan 2003
    E. TN USA
    1,501
    48
    126
    And when you make the boring bar you don't have to broach square holes for the tool bit. Round holes work OK with square tool bits for occasional use. Don't put the hole through the center of the bar, you want the cutting edge on center.
  12. #12
    Jan 2003
    Genoa, Illinois
    1,470
    11
    257
    This is the general idea of a line bore. The crank is used to feed. Some kind of motor is required to rotate the spindle. Adjust bore diameter by moving the tool farther from center.
    Jim
  13. #13
    Apr 2009
    UK, KENT
    6
    hi
    look at all portable inline boring bars and you will find all tool holes are on centre line of the bar
  14. #14
    Jul 2004
    Asheville NC USA
    8,933
    3353
    2928
    Quote Originally Posted by VECTRA1 View Post
    hi
    True, but I'll bet you'll also find they've got a line of grossly overpriced cutting tools they'll sell you for use with the on-center holes.
    If a person is making their own, it makes the most sense to put the hole off center sufficiently to put the cutting edge on center such that standard tooling can be used.
  15. #15
    Jun 2006
    glen cove ny
    115
    Default boring bar
    hello all, we set up to restore the lower pin holes on 520 dresser using 1.5 inch ground+polished line shafting 7 ft $70, 2 flange bearings $ $80 1/2 square broach $135 1.5 hyd rod wiper set in alumn plate spring loaded to lower bearig bracket to keep the chip from interfering w/smooth shaft to bearing fit. we turned top of bar to fit hougan mag drill,gave it a flat, located w/ cones from alunm round heavy tack welds on the bearing brackets and done. drill+broach 1/2 squares as needed. we stick welded worn holes. we did 2 pads 4 inches apart 1.125 thick. we used hss w/no problems, just a little bumpy to start. not enough work on LI to warrant spending on or even renting climax or the equivelant set up. surf
  16. #16
    Aug 2007
    central wisconsin
    68
    That sounds like it worked great. Do you have any pictures of your setup? What was the size of the hole you bored out?
    Vince
  17. #17
    Jun 2006
    glen cove ny
    115
    vince hole size 3.055 surf
  18. #18
    Apr 2009
    UK, KENT
    6
    hi
    have alook at swedish line boring tools it gives photos of tool in use and there not expenive
  19. #19
    Jul 2006
    Clover Hill district, WI
    2,304
    7
    Quote Originally Posted by metlmunchr View Post
    The validity here is with holes on the center. you need to grind away
    nearly half the thickness of the tool bit.
    Or work above center, but the draw-back there is if you need to cut say
    another 3 thou/side out you can't just slide the bit the .003".
    The math won't work-out.
    Realise too that with bit-holes offset, the set-screws press against
    the bottom of the tool-bit, bringing the top level of the bit-nose to shaft-center.
    Minimal grinding now does the trick.
    M1M
  20. #20
    Aug 2007
    central wisconsin
    68
    Do you have a name brand or a link for these Swedish line boring tools?
