catalytic
Cast Iron
- Feb 4, 2010
- Boston, Los Angeles, and Cleveland
I recently got a little Rusnok mill, and when it arrived the X-axis table gib had slid out, gotten hit by something, and bent/cracked (it appears to be case hardened steel or cast iron, and it hairline cracks around the bend). I just got a replacement from the folks at Electro-Mechano.
Gib Dimensions: 13" long X 0.34" wide X 0.103" thick (replacement gib) or 0.124" thick (original gib). It is not tapered.
The old gib was 0.124" thick, whereas the new one is 0.103" thick. Does this 0.021" difference in thickness matter?
Second, the new one has a slight bow. When I lay it down on a flat machined surface, it bows up 0.05" in the middle. It takes very little pressure to push the bow down flat. I don't think it can be permanently bent back to straight -- I tried that with the original bent gib and it cracked before it bent. Is this bow a problem, and if not, should it bow out towards the operator or in towards the column? (the gib is located on the operator's side of the table)
Third, should I do anything to the new one before sliding it in?
Pic of gibs:
Here is how I'm measuring thickness:
Pic of bow:
Pic of gibs:
Pic of bow:
