Peter from Holland
- Jan 15, 2005
- The Netherlands
I have a Alzmetall AC32 drilling machine
We replaced some bearings and in the proces probably ruined this small PCB with the 2 slotted optical switches
Components would cost less as €5 probably
Alzmetall wants €200,- for it
Oke we solder in 2 new switches and be good
Not so The exact same type (Sharp 04 1A15 with 5 pins ) I cannot find anymore
Looking on RS online I found there were several types
Buffer (5)
Inverter (3)
Open Collector (1)
Open-Collector with 10K Pull-Up Resistor (8)
Photodarlington (1)
Photodiode (1)
Photointerrupter (4)
Photologic (2)
Phototransistor (69)
Pull Up (2)
Transistor (59)
I presume the 0.25 on top of the switch is the slit size Gap size is ±3.2mm
Dimensions are 12x6x8mm
I found these that would fit dimensionwise
Slotted Optical Switches |Same day despatch on Slotted Optical Switches parts | RS Components
Anyone can help which one to choose ???
Peter
Buffer (5)
Inverter (3)
Open Collector (1)
Photodarlington (1)
Photodiode (1)
Photologic (2)
Pull Up (2)
Transistor (59)
Peter
