David_M
Hot Rolled
- Sep 30, 2014
- Midway, GA, USA
It's for cutting prime spur gears on gear hobbing machines that have their differential located before the index gears. Mostly Gould and Eberhardts, but there are others built this way too.
I started working on this a few months ago--I had to stop because of a big backlog of work at the shop.
This is the first permanent running release (The initial iterations timed-out to keep me from spreading untested software too far).
Try it and see if it works for you. Click here
Of course you will probably need to add/remove intermediate gears to get things synced.
