Long Tom
Stainless
- Aug 21, 2011
- Fiddlefart, Oregon
I've been working on the castings I mentioned a few weeks ago. Bought a Mit bore gauge and it works well. My 1" steel boring bar with sharp CCMT/CCGT inserts (forget which) worked fine for the outer and inner bearing pockets but there's a seal pocket deeper still that it was wanting to sing a bit on.
Looking real quick at Maritool they go up to a 3/4" solid carbide boring bar that uses those inserts and rate it at 10x extension even in steel. These castings are aluminum. I'm taking light cuts. Extension will be right around that 10x range. My question is, should I find an even stouter carbide bar- my Aloris will take up to a 1" bar of normal construction, I.E. with flats- or is the 3/4" bar really "all of that".
My only experience with carbide bars is really small ones I've used- and love- for gunsmith type work or other small boring jobs. The small one I have is indeed MUCH more rigid than the similar steel version I also have.
Thanks guys.
Thanks guys.
