oxford
Cast Iron
- Jan 28, 2011
- north east, PA
Does anyone have a source for 1235 aluminum alloy round stock? I need to finish at 43mm dia and 50mm long and 8pcs. I have no idea what it is for, the lab just said they wanted it. It looks like 1145 alloy may be an acceptable replacement for the 1235. The 1235/1145 is more common in foil/sheet stock, not so much barstock. Any help would be appreciated.
Next question is, if I can even find this what kind of job is it going to be machining this alloy? I am sure tolerances will be fairly loose on OD and length but there also needs to be a 2mm hole, 25mm deep in the center of it.
