Source for small D-Shape chassis punch?
Results 1 to 8 of 8
    Apr 2010
    Apex, North Carolina - USA
    695
    45
    62
    Default Source for small D-Shape chassis punch?
    I need to make about 8 holes for some Pomona Binding posts. The posts are D-shaped to prevent rotation. Greenlee's are too big, can't find any on McMaster (not sure I would want to buy one after seeing some of the prices for this small job)
    Is there a simple way to make one? Chassis material is 24ga steel.
    Thanks, Walt
    Oct 2010
    AB Canada
    163
    23
    27
    Do you know anyone with an EDM that can cut or sink out a punch and die set for you? possibly even a water jet for the die but I don't know what kind of tolerences you need to hold for a die. The punch could be made with a surface grinder.
    Dec 2008
    Ohio USA
    15
    Quote Originally Posted by wb2vsj View Post
    If pairs of the binding posts are spaced at the standard (for a double banana plug) 3/4" o.c., Pomona makes alignment strips with two D-shaped holes. Search Pomona Electronics for model 3862 - mounting base, double binding post. Those are black plastic and mount above the panel. Years ago, they sold (and maybe still do, but I couldn't find them) metal alignment strips, maybe 1/2" x 1" 16 ga., with two D-shaped holes that went behind the panel.
    JCav
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    I've mounted dozens of tool posts over the years and while its nice to have the D shaped punch to make holes with nice tidy flats, I cheated.
    I either aligned the posts in round 3/8 holes and lock tighted them in place or I blunt punched the hole lip to squash metal into the diameter simulating the flat. Sometimes you have to do a little filing. Either way it's quicker than the chassis punch.
    Practice a little with the punch on remnent metal and you will soon make a neat, workmanlike "D" of the round hole.
    Nov 2007
    North Idaho
    31
    Default Single d punch and die
    Check out cetooling.com they have lots of this kind of tooling -Chris-
    Apr 2010
    695
    45
    62
    Thanks to everyone for their input.
    Forrest, loctite-ing them into place was my first thought then modifying an existing hollow punch came second. Much, much cheaper too!
    I had thought about making a rudimentary punch and die but for this small of a job it's not worth it.
    -Chris- thanks for that site, it has been bookmarked.
    Walt
    Jul 2004
    MA
    107
    For just 8 holes, drill ~0.350 and finish the profile with small round file and small 3 corner file
    ExpTec
    DBA Experimental Technique
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    I've punched holes in thin sheet metal using a regular pin punch. Put a block of wood in a vise with the end grain up then smack the punch with a hammer. Shouldn't be hard to grind a flat on the side.
