clarnibass
- Dec 23, 2015
Hi
I have a Nakane live center like this one (in the 2MT size): http://www.nakane34.co.jp/center/ls_e.htm
Its largest taper diameter is 24mm. I'm looking for another "stealthy" center (i.e. body diameter as small as possible compared with taper diameter) but with a larger diameter. 26mm to 30mm to would be perfect but a little larger would be ok.
The Nakane in 3MT size would be great but my lathe has a 2MT tail. Even if reducing sleeves exist, it would lengthen it by a lot.
I can't find a center like that but maybe I'm missing some.
I rather not go into Royal prices but Nakane or Riten is ok. There are local dealers for Bison and Roehm so that's more convenient but I don't mind ordering from abroad.
The Riten Multi is the closest I've found but it's 57mm so maybe I'll get it if I really can't find anything closer.
Thank you!
Thank you!
