PackardV8
Hot Rolled
- Jun 4, 2006
- Spokane, WA
Automotive machine shop with new 3-jaw chuck with finger jaws to hold aluminum pistons by the oil ring groove. We're going to be cutting .050" - .070" off the flat top 4" diameter pistons.
What spindle speed and cross feed speed would you select? How much cut per pass?
FWIW - the tops of new pistons show a definite visible fine thread pattern, as they were probably cut as fast as possible on a CNC production lathe, so mirror finish is not necessary.
Some pistons show evidence of the center having a slight depression as if having been touched with a tool in a tailstock prior to lathe tool cross-cutting. Our assumption was so there would be no chance of leaving a tiny pigtail thread of aluminum in the center. Thoughts on that?
jack vines
jack vines
