catalytic
Cast Iron
- Feb 4, 2010
- Boston, Los Angeles, and Cleveland
I am replacing the spindle bearings on a little Rusnok (Chicago) mill.
The manual says that the lower spindle bearing is a "preloaded double row ball bearing." The original is a New Departure 5204 (same as SKF 3204) double shielded bearing. I believe it's just ABEC-1.
I cannot see any way that the preload is applied. The inner race is coplanar with the outer race, and as far as I can tell, tightening the two nuts that hold the spindle into the quill would not apply any preload (it just means that there is pressure on both sides of the outer race).
Is there any reason not to replace it with a standard 5204 (SKF 3204) double row bearing?
EDIT:The bearing's inner race is marked New Departure 5204 on one side. On the opposite side of the bearing, the outer race is marked "New Departure 5504". The 1943 New Departure Handbook says that 5504 is just a single shielded 5204, but my bearing is double-shielded. Here are the specs from this 1943 handbook:
New Departure Hand Book ... - General Motors Corporation. New Departure Division - Google Books
Here are the spec's on the replacement:
Angular contact ball bearings, double row - 324 A-2Z
Here's the spindle with the bearings on it (between the bearings is a spacer tube that covers the actual spindle):
Here's the parts breakdown of the spindle:
