Luke Rickert
Hot Rolled
- Oct 24, 2007
- OSLO
Hi I have a spindle out of a Schaublin 13 mill high speed head that is currently intended for use with a collet that is similar but different from ER20 collets. It has a 15 degree angle rather than the ER's 8 degree so there is "extra" material that needs to be removed. The spindle is integrated with a large gear so making a new one is not a good option.
I would like to find a company that can machine/grind the spindle nose out to an ER20 profile so I can actually use the head as I only have one 6mm collet for it right now and cannot find any more or even identify the collet. I could in theory hard turn it on my Schaublin 135 lathe but I am a little worried about messing up a part I cannot easily replace.
One concern of grinding the spindle is that it may only be case hard which would mean my new surface would be soft so perhaps I should insert a hardened sleeve and grind it out to a smaller ER16 and make a custom nut. (the current threads are M25x1,5 so a normal ER20 nut will work)
thanks
Luke
thanks
Luke
