J_R_Thiele
Stainless
- Jan 22, 2003
- Columbia Missouri
I have a new to me Biax scraper and earlier this week talked with Matt at Dapra. Matt was very helpful. My scraper, a 4/EASL, was made in 1965. The scraper was doing fine- but I wanted to findout what I could. Matt cautioned be to not "push" this scaper too hard in roughing, as it had a phenolic spiral gear which could be stripped- and they had no replacements for. He also suggested I check the brushes. They do not have those either- but indicated something close could be fitted.
About 2 hours of use (after I talked with Matt) the scraper quit- and I belive I reached the end of the line with the brushes. I found some at the hardware store which are OK in width, but thick by .025. I was planning to mill then down to the correct thickness. I do not know how long the origninals are- and the spring, wire and end on the new ones are different also. I was going to try and unsoder the old end and put the old spring and end on the new brush.
Is there any way to determine how long the new brush should be? What I have left is .160 past the spring, and the new one is .550 long
Any suggestions on how to hold the brush to mill it? I assume it is brittle. Would I be better off to try and sand it or file it down?
I have not done anything like this before.
