BACH
- Oct 28, 2005
- Durban South Africa
I am busy with a proposal for a customer, part of which requires an hydraulic motor to drive a 4 wheeled "trolley", weighing 10 000 Kg. The trolley will travel, at very slow speed, forwards and backwards over a distance of 15 metres on the level. The track is rail line. The contact diameter of the wheels is 280mm. The motor will drive 1 axle via chain and sprocket arrangement. The hydraulic power pack will supply 11 litres/min at 200 bar pressure. How do I calculate the torque rating of the hydraulic motor, if I start at a 1:1 sprocket ratio? Obviously the sprocket ratio can be changed to reduce the torque required, but will also reduce the (non critical) speed.
If anyone can help it would be greatly appreciated. If I can swing this job it will go a long way to erasing the pain of the shafting I posted about recently.
Best regards
Tony
Best regards
Tony
