Hi All
I'm just starting out in machining and am going to get myself a manual mill as I like the idea of creating pieces by hand. My main reason is to build my own dive gear so I'll mainly be machining plastics at the start (Delrin) and I have a couple of questions about the mill I should get and the equipment I need along with more specific ones about plastic feed rates and cutting speeds.
Firstly the equipment I am thinking of getting is a standard mini-mill, DRO's, Rotary table, and then the milling bits and consumables.
In relation to the rotary table I have a question as one of the pieces I may be machining will be about 180mm (7 1/2") in diameter but the rotary tables that fit on the mini mill are about 4" diameter so that leaves a massive discrepancy. Are there jaws available for a chuck that essentially overhang the exterior radius of the work piece so you can hold larger pieces in a smaller chuck? Would this cause vibration issues even with soft plastic?
Secondly if anyone has any tid-bits of info, or can direct me to useful guides on the web about cutting speeds and machining Delrin, the types of tools to use etc I would greatly appreciate it.
Cheers
Jools
Cheers
Jools
