motorfixer1
- Nov 14, 2012
- Illinois, USA
Hey all I've been away for a while (works been crazy) but I was searching today for some answers. I routinely machine an electric motor shaft on our Kingston HD 22X90 manual lathe. The shaft is about 5" for half and about 3" on the other half and 60" long. Material is 4140 HR. I use a steady rest in the center of the shaft to prevent chatter and it works well for the most part but I have noticed that the rollers cause their own vibration influence on the workpiece. After roughing out the shaft in another machine (American Pacemaker 26X96) I move the workpiece into the Kingston for finishing. In the center of the workpiece I start out by machining a spot for the steady to ride on with a TPG 320 insert taking light cuts until the surface cleans up and runs true with the centers. After a light polish with sandpaper I adjust the steady to contact the freshly machined surface. No matter how smooth the surface looks there always seems to be some audible vibration from the steady as well as some effect on the final surface finish of the part. The inserts for finishing are Kyocera VNMG 331 cermet. These inserts produce cadillac finishes on steel and last FOREVER. I was thinking about posting a video of the part in action as I am in the middle of making one. I am wondering if anyone has any advice in deadening these vibrations or stopping them all together. I make some brass caps for the fingers of the steady but they aren't really practical for higher speed, extended turning operations. http://www.practicalmachinist.com/vb/general/kingston-hd-lathe-steady-rest-bushings-w-pics-262562/
