Steel Wheels made to run inside 2" Steel Channel....source?
Results 1 to 1 of 1
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,744
    1328
    2191
    Default Steel Wheels made to run inside 2" Steel Channel....source?
    Looking for wheels made to run inside 2" channel.....
    Is there such thing for purchase, or are they hidden in this barstock on my shop floor?? I better looky in the Mc-carr catalog I guess.....
    dk
    Edit:
    Found "Flanged track wheels" in MMC cat. 113 P. 1295.
    To large an OD for smallest size listed....3.250
    And at $29 each.....way to costly.
    Edit:
    Oh well, if C Channel has the same angle as Beam, then clearly I need "Beam Trolley Wheels"....that will fit -inside- 2" channel.
    I bet they don't make 'em that small.....
