I have been grinding with brand new Taft pierce surface grinders since 1963 and have never heard of this .There is such a thing as a "flush step pin guage" go-nogo fixture that will allow you to check the depth of a step or counterbore from the top surface of your product.I havvnt made one in many years. Edwin DirnbeckI posted this in the "abrasives" forum but maybe I'll get more response here.
I heard the term "step grinding" the other day in relation to extreme accuracy. Can anyone explain the process to me? Thanks
suppose you have a block that is 3"x4" x 5"tall and the 4" side needs to be perpendicular to the 5" side. you grind the 3" dim. so that both sides are parallel and to size, and you grind the 4" dim. until both sides are parallel and to size. then you stand it on end and grind one side of the 5" dim. to just clean it up. Check the perpendicularity of that ground 5" dim. to the 4" side. Suppose it is .001" out. now you put the ground 5" surface down on the chuck and dust the unground side to just clean it up. then you figure out which way you need to make the part lean to get it to be perpendicular and you start on that side and grind .001" deep across the part but you don't go all the way. you stop about .050" from the edge. then you flip the part over put that side down and grind the other side to just clean it up. then you check it. you may have to do this a couple of times to fine tune it. it is better to use a squaring block or clamp it to a very good knee. but this will work in the absence of proper tools, or if the part is too big or to small for them. you must also remember to use good grinder practice and safety. be sure to block the part in whilst you are grinding it because when you have the side with the step on the chuck there is very little contact.
I heard the term "step grinding" the other day in relation to extreme accuracy. Thanks
It's basically the best and fastest way to grind parts absolutely square. Use whatever you have to get it close and then step grind to get it absolutely perfect expecially on large blocks that are heavy. Much more accurate than relying on angle plates or squaring blocks.suppose you have a block that is 3"x4" x 5"tall and the 4" side needs to be perpendicular to the 5" side. you grind the 3" dim. so that both sides are parallel and to size, and you grind the 4" dim. until both sides are parallel and to size. then you stand it on end and grind one side of the 5" dim. to just clean it up. Check the perpendicularity of that ground 5" dim. to the 4" side. Suppose it is .001" out. now you put the ground 5" surface down on the chuck and dust the unground side to just clean it up. then you figure out which way you need to make the part lean to get it to be perpendicular and you start on that side and grind .001" deep across the part but you don't go all the way. you stop about .050" from the edge. then you flip the part over put that side down and grind the other side to just clean it up. then you check it. you may have to do this a couple of times to fine tune it. it is better to use a squaring block or clamp it to a very good knee. but this will work in the absence of proper tools, or if the part is too big or to small for them. you must also remember to use good grinder practice and safety. be sure to block the part in whilst you are grinding it because when you have the side with the step on the chuck there is very little contact.
The explanation is close. You don't want to grind the opposite side from the step side until you have the stepped side square. Then grind the opposite side. This allows you to repeat your set-up on the stepped side. It is like shimming but with much more control. Sometimes it's as little as a .0001-.0002 step to get it perfectly square. I've used this method a lot .suppose you have a block that is 3"x4" x 5"tall and the 4" side needs to be perpendicular to the 5" side. you grind the 3" dim. so that both sides are parallel and to size, and you grind the 4" dim. until both sides are parallel and to size. then you stand it on end and grind one side of the 5" dim. to just clean it up. Check the perpendicularity of that ground 5" dim. to the 4" side. Suppose it is .001" out. now you put the ground 5" surface down on the chuck and dust the unground side to just clean it up. then you figure out which way you need to make the part lean to get it to be perpendicular and you start on that side and grind .001" deep across the part but you don't go all the way. you stop about .050" from the edge. then you flip the part over put that side down and grind the other side to just clean it up. then you check it. you may have to do this a couple of times to fine tune it. it is better to use a squaring block or clamp it to a very good knee. but this will work in the absence of proper tools, or if the part is too big or to small for them. you must also remember to use good grinder practice and safety. be sure to block the part in whilst you are grinding it because when you have the side with the step on the chuck there is very little contact.
When I hear someone say step grinding I think about just using the table travel and down feed. Not the in/out feed.
Then feed down in the same place then raise the wheel up and move over the width of the wheel and feed down to the level you just did and step over and over again feeding down. You feed with hand wheel about .001" ever time the table changes directions. Really speeds up the grind. Have to use a lot of coolant. Then after you get to your depth all the way down, you remove and clean, dress wheel and put it back on and grind it the regular way.
Notice
