chassis_builder
- Dec 25, 2009
- TX USA
This is my first post here and I am not sure if this is in the right section but I couldn't find a section that seems to be dedicated to this subject. If necessary a moderator can move it. I have an Accurite II DRO on my milling machine that has quit working. I have been leaving it on all the time and a few days ago we had some storms come through here and the power was off for a few hours overnite. Usually when that happens the readout just goes to two small vertical bars on the left of the display and when you press the reset button the normal display comes back on. Now when you press the reset button the display comes on but flickers slightly but when the button is released the display goes back to the little vertical bar at the left. Is there anything to check and see if this can be fixed or am I looking at a new unit? I checked the fuse on the back and it seems to be OK. Any help will be greatly appreciated.
