mjk
Titanium
- Oct 20, 2005
- Wilmington DE USA
I have a wedge type "C" size qctp that is probably a Phase II.
The tag is no longer attached and the only marking is a "42" stamped on the side.
I decided to take it apart to see if I could get a smoother release.
Found crud in the bottom of the housing and the screw has some rust.
The lock lever has a groove on the bottom that looks to accept an o-ring that would probably seal the internals.
Am I correct in there should be an o-ring?
How often do you take yours apart for a thorough cleaning?
Lubricant?
Mike
Lubricant?
Mike
