I have a table saw that I picked up used. Unfortunately, there is blade wobble sufficient to cause scorching on harder woods. There is deviation of about 1/16" at the edge of the blade. I'm pretty sure that the problem is a result of the arbor flange not being symmetrically machined. I've laid a blade on a flat surface, and it seems perfectly flat. I've also swapped out the blade, and the wobble persists. I found the following suggested solution to the problem:
http://woodgears.ca/saw_arbor/
and have not had much luck. I have a sharpening block that seems to get worn away without solving the problem. I can get a replacement arbor very cheaply, but don't have the equipment to press-fit it to the motor spindle.
So, it seems that I have two solutions:
Using some sort of file on the flange (diamond?) and see if I can remove enough material to stop the wobble OR ordering a replacement arbor and trying to find someone who can remove the old one and install the new one. Any ideas? Thanks.
