Tailstock "drill pad": legit device, or risky business?
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    925
    Default Tailstock "drill pad": legit device, or risky business?
    Pretty simple concept: stick a drill bit in the headstock, stick the drill pad in the tailstock, locate the work in the vee groove, and be careful
    Does it have a legit use, for modelmakers, perhaps, using small lathes, small bits, etc?
    Or is it simply an accident waiting to happen?
    Oct 2009
    Louisville, KY, USA
    721
    198
    125
    I'll vote legit device. How is it any different from holding a piece of metal on the table of your drill press?
    I can see that it looks a little hairy since it's at right angles from the usual orientation, but that's an old technique. It might seem weird now, but it wasn't uncommon for a lathe to be someone's first piece of equipment, especially in a hobby shop, so having it do the work of a drill press as well was quite valuable. It hasn't always been possible to buy a drill press with your left over lunch money. I think the value of a drill pad comes from a time when drill presses were less common.
    I've done the dicey looking thing where you center drill with the drill in the head stock and the other end of the bar on a center in the tailstock. (...and your hand on the work to keep it from spinning.) It works great. It's a good way to ensure your center holes are lined up on a rough casting or other irregular work piece. I've clamped stuff to the lathe carriage for boring and I've used an angle block on the carriage to hold so I could drill large holes with back-gears and power-feed.
    I wouldn't use the a drill pad or crotch if I had a drill press available, but that is mostly a matter of convenience. (I think the one in your illustration is a crotch, while a drill pad is just flat.) My drill press is always set up with a drill chuck and a table, while the lathe is under a tarp and would need to have tooling swapped out to do that work.
    On the other hand, I've never figured out how you're supposed to drill through-holes with that stuff without poking holes in them. I can think of a few ways, but they seem impractical and time consuming. Once again, it only looks like a useful tool if you don't have a drill press.
    May 2003
    Iowa
    10,073
    3194
    3867
    Our safety people would puke all over that. Hold the part by hand? Not in our shop.
    For a home shop, different story. The only bad thing is how to apply coolant or oil with one hand on the tailstock wheel and the other holding the part?
    JR
    May 2006
    Rootstown, OH
    184
    81
    61
    The use of a crotch center is illustrated in South Bend's "How to Run a Lathe", for what it's worth.
    Dec 2005
    Auburn, Alabama
    1,438
    114
    121
    Legitimate device and risky business.
    There are those for whom a table fork is an accident waiting to happen. Machinery is less forgiving.
  6. Likes S_W_Bausch, adama liked this post
    Jan 2005
    CANADA
    Saskatchewan
    9,436
    1138
    3175
    Quote Originally Posted by JRIowa View Post
    JR
    That's what your mouth is for: take a big swig of coolant or cutting oil before you begin and practice accurate spewing
  8. Likes 32995, aerodark, fusker liked this post
  9. #7
    Dec 2000
    Bremerton WA USA
    10,633
    40
    4048
    What happend when you break through?
    This is NOT an aid for through drilling.
  10. Likes oldbikerdude37, 4GSR liked this post
  11. #8
    Mar 2001
    Switzerland
    2,423
    2015
    998
    I use one from time to time for small diameter stuff, like 3/8" rod. I wouldn't want to go much bigger than that, like was said, the breakthrough is the bear.
  12. #9
    Mar 2001
    Marlette, MI USA
    445
    8
    I'd vote for both risky business and legit device. I cut my teeth on the 1932 edition of How To Run a Lathe, and, Like fciron, I've done all those risky procedures at one time or another (after all, that's what my user name is about), BUT I feel a lot better doing these things on an old school, underpowered belt driven machine like a 9" South Bend than a modern machine like a 15" Colchester that has enough power to kill you. I guess it needs to be kept in prospective-stuff that worked OK back in the day often should not be mixed with modern speed and power.
  13. #10
    Jan 2010
    5,475
    2426
    925
    I think a nifty shop project could be a shop-built self-centering vise on a tailstock pad, but the hand-held workpiece method s a great opportunity to feel stupid (and remember to buy bandaids).
  14. #11
    Dec 2005
    Germany
    630
    43
    Make a small cylinder that fits the outline. Drill and tap 1/4" two times so both parts rest on each other, put the part in, bolt it down, drill through.
  15. #12
    Oct 2009
    Louisville, KY, USA
    721
    198
    125
    As I said, hobby shop use and historical. I really think the set up time on the lathe makes them redundant.
    A quick google search shows one that sold for $20 recently. Figure in ten bucks shipping and you've just about bought a crappy drill press. No need to set up the lathe. The same provisions about not pushing too hard apply to your $30 drill press as apply to that pad, but you can clamp stuff to the drill press table.
  16. #13
    Mar 2006
    Cape Cod, Massachusetts
    4,829
    1133
    1877
    Quote Originally Posted by Forrest Addy View Post
    Well, I have one with a center hole in the V, runs all the way through the taper. Takes care of the breakthrough problem, provided the drill is smaller than the hole
    Still, I've never felt the need to use it. It just came in a box of accessories with a lathe.
  17. #14
    May 2003
    Iowa
    10,073
    3194
    3867
    Quote Originally Posted by HuFlungDung View Post
    Ok, what the hell do I do with my cigar then?
    Both hands are busy, my mouth is full of coolant...don't go there Hu
    JR
  18. Likes 32995 liked this post
  19. #15
    Feb 2008
    Glade BC, Canada
    632
    587
    122
    It is however a sure way of having the hole intersect the centerline of the shaft accurately. Otherwise you have to make a jig or use a "v" block with a centering fixture to get the same result. It's just quicker for one offs. Peter
  20. Likes davycrocket liked this post
  21. #16
    Jan 2008
    spokane
    855
    5
    83
    Ues it as a combination tool on the press - straighten round shafts & flat work.
  22. Likes S_W_Bausch liked this post
  23. #17
    Feb 2008
    Glade BC, Canada
    632
    587
    122
    JR, Stick a piece of steel brake line through your cigar and a broom up you know where then you can smoke, squirt coolant on the job and sweep the floor too. Aint multitasking great. Peter
  24. #18
    Sep 2005
    San Diego
    3,168
    488
    779
    Quote Originally Posted by fciron View Post
    Hi there Mr. Fciron:
    I have question for you...?
    In a lathe set up, I wanted to center drill the end of a 1/2" - 18" long shaft.
    So I gripped one end in a headstock chuck. I gripped it semi-snug about 3/8" deep in the jaws. I did this while holding the shaft "eyeball" straight. Then with the lathe turning VERY slowly, I began moving the cross slide in and began to push the shaft end with a mounted block as though I was edge finding on a mill. The rotating shaft was the "edge finder." I noticed when the shaft was running true the cross slide began to give me back pressure on the handle. I stopped the machine and tightened the chuck well, and then drilled the center hole.
    My question is, have you ever done this, or seen it done?
    I don't mind telling you I was a bit nervous, but the result was very satisfactory.
    I ask you because you seem to be a seasoned machinist. I've been a mill machinist almost exclusively.
    Regards,
    Stan-
  25. #19
    Jan 2008
    philly
    306
    17
    What size lathe is it for?
    I am a clockmakers and would comfortably use a tailstock v-block like that to drill small (~1mm) cross holes in clock arbors. Schaublin makes them for the 70 series. For smaller stuff, no problem. This kind of tool is, to me, a clockmakers 'cheater' for extending the usefulness of the basic bench lathe.
    I aslo have a 3" dia flat drill pad that fits into the tailskock of my Stark #4 that converts the lathe into a reasonably powerful horizonal drill, far more powerful than my little High Speed Hammer drilling machine.
    Rich
  26. #20
    Dec 2004
    uk
    12,418
    3432
    5540
    I was contemplating one but most of the odds and sods im doing start out size wise more like cross drilling a 1" stainless pin. Would save haveing to set the mill up and find center every time. Then like mentioned above the thought of the drill catching, spinning part up and the drill then snapping kinda put me off the idea. As a kid i had a 2' diameter wood bowl i was turning come off a wood lathe. Between bouncing of the garrage walls, the lathe and me it was destroyed and i was left pretty well beat up. That was a nice smooth nearly finnished bowl. A stainless pin with a pointy bit of drill bit is going to be at least as painful at even half the speed!
  27. Likes 4GSR liked this post
