I've searched this forum and google for information on how hard in Rockwell Hardness Number a tailstock quill generally is and can't find a thing. Do any of you guys know or know where I can get the information? The lathe is a 14 X 40 Rockwell model 25-210.
I'm trying to determine what type of insert to use to cleanup a 3MT in a hardened quill prior to finish grinding. Besides the quill being hard the DOC will be only a few thousandth at a pass and I know most inserts perform better when the minimum DOC is taken. Which is generally much more than a couple thousandths.
I'm guessing 0.010" to 0.015" needs to come off before finish grinding and the quill nose will probably need to be cut back.
I have already tried cleaning it up with a new HSS finish reamer but the reamer wouldn't touch it.
