J
Johnny Larue
Guest
so I come here sometimes over the years and have not contributed but have gained some info....so now its my turn to give back to other machine heads....I was going to respond to this old thread but it would resurrect an old 2009 thread
http://www.practicalmachinist.com/vb/general/tantalum-has-anyone-machined-176225/
so I am here to respond to this old thread of which little info can be obtained about the settings for machining TANTALUM. We all know the easiest way is wire EDM. Then secondly milling with a HS MILL at slow speeds with high feeds and coolant like trim-sol will even work....easy....but turning it is another matter...so I will give you some settings that have given me great success that was due to much trial and error....which should save anyone in the future some time and experimentation...as always these setting are not in stone and can be modified slightly....this was turning a 5/8 rod down to 10mm =/-.0015 by about 2 1/2 inches long....pure tantalum
TOOL BIT - 1/2 HSS square with SHARP POINT WITH HUGE RAKE...(chip should curl nicely or sharp point is gone and you need to regrind sharp) grind nice curl/rake on cutting edge to the point.
SPEED - 420 RPM
FEED - .0026 inches per revolution
DEPTH OF CUT - 0.01 total or .005 per side
COOLANT - thin film applied with acid brush of VACTRA #2 or similar oil (used MOLY-D cutting fluid also works good but don't like the fumes and possible toxidity)
FINISH CUT - same as above 0.01 worked really well for fine finish
final polish was with oil on part rubbed with 120 grit wet or dry emery paper at same speed above and just back and forth over finish maybe 8 times is all
well hope this helps you....and good luck if you modify my settings and maybe find a better way or coolant....if you do...post up what ya found like I did so we can all benefit....your gonna like these settings though
PS...I did this on a manual lathe and hand ground the bit....tried running it in a live tooling CNC lathe with no luck but was using a hand ground huge rake carbide NPR 50.1 and a 51 and a 52...tried em all...also ground those bits sharp and tried there kennemetal factory radius too.....no good...all broke...wore super quick
SPEED - 420 RPM
