Taper pin question
Results 1 to 18 of 18
    Mar 2013
    galt California
    126
    37
    63
    Default Taper pin question
    I have a German machine I am working on , it has Metric taper pins , 10X50 mm pins. I can find metric pins at Granger and McMaster but I cannot determine the reamer . Are metric and standard taper pins the same degree of angle ? \
    Dec 2000
    Bremerton WA USA
    10,603
    40
    3955
    Metric taper pins are hard to find inthe US for some reason. Got a European source?
    If this is for in-house use, it's probably simpler to re-ream the pinholes and use Imperial pins, The taper is close 1./48 vs 1/50 and I've never seen a taper pin fitted to stock length except in brand new equipment. Generally, you have to cut and fit each one to suit the re-reamed hole it's made for.
  3. Likes Illinoyance, AlfaGTA liked this post
    Dec 2008
    New York
    7,979
    2111
    Quote Originally Posted by jumpinjimmy447 View Post
    no taper angle is different
    Dec 2005
    Jersey Shore
    3,795
    276
    442
    Yes they are NOT the same taper. An imperial is 1:48 so 1/4" per foot, a metric is 1:50 so the taper is 1mm each 50mm, or about 6.09mm per foot or .241 inches per foot. close but not the same.
    Sep 2004
    RSA
    1,131
    291
    198
    Metric pins are 1:50 .
    I used to ream A LOT in printing machines and I found that taper reamers must be of good quality.
    Mar 2013
    galt California
    126
    37
    63
    THANK YOU GUYS SO MUCH !! helped me a lot . just had to stop the tec from reaming the holes with my #7 pin reamer . I was telling them it appeared the same but I was not 100% sure . not a big difference but I will let others make the call what they want to do . Thanks
    Mar 2013
    galt California
    126
    37
    63
    Quote Originally Posted by AlexO View Post
    That's funny , we manufacture containers from paper for fast food , our print presses used to all be USA machines , that's why I'm the only guy in the plant that even have taper pin reamers. LOL
  9. #8
    Jul 2009
    Peoria, IL
    10,638
    36
    7912
    Why not just ream for an inch pin and install that? You're already reaming.
  10. Likes Limy Sami liked this post
  11. #9
    Jan 2007
    Norfolk, UK
    16,519
    12144
    11565
    Talking of taper pins - aren't they a horrendous price? ..especially the small sizes, ......what we used to buy by the gross - and latterly 100, are now sold singly.
  12. Likes lazz liked this post
  13. #10
    Garbsen, Germany
    1,682
    698
    428
    You can buy 1:50 taper pins and reamers from ebay.de. Search for Kegelstifte and Kegelreibahle respectively.
  14. #11
    Feb 2008
    Illinois
    1,178
    50
    337
    McMaster Carr:McMaster-Carr
  15. Likes rustytool liked this post
  16. #12
    Feb 2002
    Peralta, NM USA
    5,311
    37
    282
    If you're going to do more than a couple of holes spend the extra to get the reverse spiral reamers - they eject the chips out the front of the hole and work a lot faster than straight flute reamers, faster enough that you have to take a little care in the work.
  17. #13
    Mar 2012
    Geilenkirchen, Germany
    1,688
    1066
    799
    Quote Originally Posted by rke[pler View Post
    Yes that's true, but they also like to wander more than straight flutes, so they are not so suitable for careful hand reaming. Read dangerous.
  18. #14
    Mar 2013
    galt California
    126
    37
    63
    Quote Originally Posted by ewlsey View Post
    Well normally I would , but the machine is a million bucks or more , they flew a guy from Germany here to over see the repair , if they want metric pins , they get metric pins .
  19. Likes Leg17, SIP6A, Limy Sami liked this post
  20. #15
    Jul 2009
    Peoria, IL
    10,638
    36
    7912
    Understood.
  21. #16
    Sep 2005
    il.
    6,531
    29
    1161
    All world machinery
    in Chicago (Harvey)
    for metric taper pins with tapped hole in big end
  22. #17
    May 2002
    South Central PA
    12,436
    1507
    2616
    Here's a good source of metric pull pins in small quantities - DIN 7978A Taper Pull Pins
  23. #18
    Jul 2009
    Peoria, IL
    10,638
    36
    7912
    Quote Originally Posted by wippin' boy View Post
    All world machinery
    in Chicago (Harvey)
    All World is in Machesney Park, IL on the north side of Rockford. Great company.
