Page 1 of 3 123 LastLast
Results 1 to 20 of 47
    Kenre is offline Aluminum
    Apr 2007
    Melbourne Australia
    88
    Default Taper turning attachments
    Due to the exorborent prices i have seen these things sell for, And that i enjoy making things myself, Ive decided to build a taper turning unit for my lathe. (not going to mention brand) hehe.
    Does anyone have, or know where i can find plans for these? Ive never had a close look at one to nut it out myself.
    Also be great to hear of mods and experiences etc.
    gbent's Avatar
    gbent is offline Diamond
    Mar 2005
    Kansas
    4,005
    Unless you just like making machine parts, find a hydraulic tracer attachment instead. Many times the usefulness, and portable from lathe to lathe.
    Mike C. is offline Diamond
    Nov 2004
    Birmingham, AL
    9,822
    http://www.kinzers.com/don/MachineTools/lathe_projects/
    Google is a wonderful thing. Simple search for "making taper attachment". First hit.
    Nov 2004
    Birmingham, AL
    9,822
    Forgot to add, most hoe grown TAs will be of the non-telescopic type. This requires removal of the cross feed lead screw to allow the TA to draw the slide. DOC is then controlled with the compound. Atlas TA is of this type.
    lazlo's Avatar
    lazlo is offline Titanium
    May 2005
    Austin, TX
    3,808
    Most of the home-built taper attachments are non-telescoping. Meaning, like Mike says, that you have to disconnect the crossfeed leadscrew to turn a taper. This is a lot easier to do on some lathes...
    A telescoping taper attachment is a much bigger project...
    You might consider just finding a taper attachment from a lathe of similar size, and re-fit it to your lathe.
    Funny thing about taper attachments: they seem like status symbols. You rarely use one, but everyone wants one on their lathe
    Jim Shaper's Avatar
    Jim Shaper is offline Stainless
    Nov 2007
    Minneapolis
    1,618
    How often do you need to turn a taper that you couldn't make by just turning the compound to the correct angle?
    Maybe I'm spoiled with 6.25" of compound travel.
    jims's Avatar
    jims is offline Cast Iron
    Sep 2004
    Sonora , Calif
    404
    Default Turning a taper
    You might want to search for the tool I made to cut tapers . The one I made only has a
    stroke of about 6 inches but one of these days when it warms up I'll make one with a longer stroke. I think it works great. If you want i'll send you a print.
    search for jims homemade taper slide tool.
    gwilson is offline Diamond
    Oct 2006
    williamsburg va
    5,300
    You can make a simple adjustable set over center for the tailpiece. Brownell's used to sell one. I made one by attaching a Derbyshire jeweler's lathe cross slide,a larger than usual cross slide of its type-about 4" long,to a tapered center to fit into the tailstock. Attached a hardened steel 60 deg. center to the side of the slide that faces the headstock. You do have to turn between centers to make tapers with it. Otherwise,I set the compound to turn tapers. A real taper attachment would be the best if you take the time to make it. WHAT SIZE AND TYPE LATHE? I have a few old ones laying around. One is for about a 14-16" swing Southbend lathe. It is old,brown,and dirty,but I know it was never actually used. Make an offer. Yikes,I just noticed you are in Australia. Shipping would be expensive.
    Metalcutter's Avatar
    Metalcutter is offline Titanium
    Sep 2005
    San Diego
    2,413
    As long as you are going to go to all the trouble, why not just jump to the "speed of light" and design it to accept a template which can be a "form" of your choosing?
    Then you could turn shapes as well.
    Spring load the slide to follow the shape on the back side of the attachment and if you run off of it, the tool would just move away from the work.
    Just a thought.
    Regards,
    Stan-
    David Carlisi is offline Stainless
    Nov 2007
    Alpharetta, Ga USA
    1,427
    Quote Originally Posted by Jim Shaper View Post
    True, but you can not single point tapered threads that way. To single point tapered threads on a manual lathe, you need a taper attachment.
  11. #11
    Oct 2006
    williamsburg va
    5,300
    I have a little Lehigh manual tracing attachment. I can cut tapered threads with it to make things like buffer spindle ends. Trouble is,these little manual,non hydraulic taper attachments are pretty rare. Template follower mentioned above is something I've been planning to make for years. My tracer only does abt. 1 1/2" stroke. then,I have to piece it to get more.
  12. #12
    jims's Avatar
    Sep 2004
    Sonora , Calif
    404
    Default tailstock offset for taper
    Gwilson
    I made a tool to offset the tail stock for cutting tapers. I am going to pull
    the center out and replace with a hemispherical ball point on the end.
    Mine locates on the outside barrel of the tail stock. Indicate top true then adjust offset.
    jims
  13. #13
    Jeff_G is offline Hot Rolled
    Aug 2004
    Granite, MD USA
    824
    Quote Originally Posted by Metalcutter View Post
    ... design it to accept a template which can be a "form" of your choosing? Then you could turn shapes as well. Stan-
    Sounds like a good idea. What would you suggest for a template follower? Ball bearing?
  14. #14
    clutch's Avatar
    clutch is offline Hot Rolled
    Feb 2006
    Northern LP of Michigan
    678
    Are ball centers and lathe dogs used often in tailstock taper turning?
    Clutch
  15. #15
    Marty Feldman is offline Stainless
    Feb 2005
    Owl's Head, Maine
    1,107
    Here's another homemade job, a la gwilson and others above. Fits in MT2 socket of Myford TS.
  16. #16
    jims's Avatar
    Sep 2004
    Sonora , Calif
    404
    Default Holes for different tapers.
    Marty
    I am sure the holes are like the ones I made for my taper slide. Each hole pinned returns you to preset taper? Right? I used roll pins but would have used tapered pins if I had them.
    Hole one equals mt#1 ect.
    jims
  17. #17
    Jim Shaper's Avatar
    Nov 2007
    Minneapolis
    1,618
    Those holes are only accurate for a given length of stock though. Change the distance between centers and your indication is hosed.
  18. #18
    lazlo's Avatar
    May 2005
    Austin, TX
    3,808
    Quote Originally Posted by clutch View Post
    For turning tapers with a tailstock set-over, sometimes it's more convenient to use an attachment like GWilson's first post or Marty Feldman's.
    But in either case (either moving the tailstock, or using the tailstock taper device), when you set over the workpiece, it tends to bind if you use a conventional 60° center. So you can either make a ball-tipped center, or use a Bell Center drill to cut a concave countersink, which rides nicely on a 60° center, even when set over.
  19. #19
    Nov 2004
    Birmingham, AL
    9,822
    Big disadvantage of the off set tailstock (and you can just make a center for your boring head and do the exact same thing) is that you still can't use the chuck for holding the headstock end. Offset taper turning requires the use of centers and dogs.
  20. #20
    Sep 2005
    San Diego
    2,413
    Quote Originally Posted by David Carlisi View Post
    What's the difference if the carriage is being "pulled" by the feed or the thread drive?
    The cross slide will still follow the profile. No?
    I just need further explaination.
    Regards,
    Stan-
