Taping 18mm hole ( aluminum )
Results 1 to 12 of 12
    Feb 2018
    Illinois
    Default Taping 18mm hole ( aluminum )
    Hi Guys,
    Not sure if this good forum but I will give it a shot.
    I have an 18mm hole in water distributor... I need to thread so it accepts a fitting ( to be custom made ) current was glued in.
    Is 20 x 1.5 tap a good choice ?
    I read somewhere that there is something like starting tap its conical to help center the tap.
    Any recommendations on specific tap brands, I will be doing it manually.
    Thank you
    May 2014
    Montana
    254
    184
    134
    If you got the old one out cleanly, why not clean the hole up and glue in the new piece?
    20x1.5 threads expect 18.5mm hole. Don't know how much problem that .5mm will cause if you tap.
    Feb 2005
    8,467
    11836
    9572
    20x2.5 is a standard size..
    Major minus pitch gives you your hole size, 17.5mm..
    You're at 18mm, and that would still give you a better than 60% thread,
    which should be MORE than strong enough considering the previous plug was
    glued in. If it was a J thread, you would be at 70%..
    20x1.5.. In aluminum, you can get that tap to go.. Its not going to be fun,
    and its not going to be pretty, but it'll go... And you might get some nice
    self locking threads out of it in the end. Or you could ream it out and then tap.
    Though 20x2.5 seems a lot easier.
    I'm assuming you are talking about hand tapping... 2 fluters are a bitch to start straight,
    3 or more flutes will generally let you feel when you are lined up nicely.. Though I would think
    a 20mm tap of any flavor would have at least 3 flutes.
    Mar 2005
    Germany
    472
    41
    Metric hand taps are serial.
    For standard coarse it's a three tap set, start, rough, finish.
    For fine threads (which 20 x 1.5 is) it's a two tap set, start and finish.
    In aluminium I'd use ethanol or kerosene for lube. WD40 also works.
    Feb 2007
    Aberdeen, UK
    2,882
    1029
    992
    1/2" NPT will go straight in, then unless you're doing something very unusual you should have no problem finding an off the shelf fitting.
  6. Likes Bobw liked this post
    Jul 2005
    Cottage Grove, MN 55016
    6,375
    3398
    3761
    http://vikingdrill.com/pdf/section/v...Dies2016-1.pdf
    This St. Paul, MN company is one of the 2 remaining drill and tap mfg. left in the USA. I have been inside their plant and it's a mix of the very new CNC and the old manual machines. They make superior grade tools. Also they have an 800 number you can call and get questions answered if you can't find the answer on their web-site.
    Mar 2005
    Germany
    472
    41
    Quote Originally Posted by gregormarwick View Post
    Good point, 1/2" NPT should do the trick.
  9. #8
    Jun 2012
    Michigan
    8,564
    2551
    2912
    Starter taps were a tap with a tapering nose that would take a smaller bite and so would tap easier than a more blunt nose tap. Because of the taper one may have needed to followed with a normal tap to make good the threads for a shallow hole. One style of a blunt nose tap was called a plug tap and was often designed to push the chip ahead of the tap so was a very good high production machine tap..with a threw hole or enough hole to fill with chips.
    Irwin has come out with a starter tap that has perhaps 4 threads at the beginning of the tap that are made the diameter of the tap drill, so leading a starter design tap straight into the drill hole. They need even more depth of hole to make good thread at the beginning of the hole. Hole need be perhaps 1" deep to get perhaps 1/2"+ good thread..Or yes one could follow with a normal tat.
    I used the Irwin tap yesterday for the first time (3/8-16) in aluminum..
  10. #9
    Jul 2005
    6,375
    3398
    3761
    Viking has a slick deal too.. It's an Index box with the tap drill and next to is the tap. Very convenient.
  11. #10
    Feb 2018
    Illinois
    Hi Guys,
    Thank you, here is what I'm trying to do..
    955/957/958 Cayenne DIY: Fixing the coolant manifold fitting with a threaded adaptor - Rennlist - Porsche Discussion Forums
    Do you guys still think that I should go 1/2 NTP ? Straight in ?
  12. #11
    Feb 2005
    8,467
    11836
    9572
    Quote Originally Posted by Ndx View Post
    Hi Guys,
    That would be REALLY easy.. And you can probably get a barbed fitting down at the hardware
    store for about $3.
  13. #12
    Nov 2013
    Utah
    2,462
    677
    1306
    I'm still trying to figure out how Tape is going to help anything.
    Sorry couldn't help it.
    R
