Metric Amce Thread?
CordyCNC
Oct 16, 2007
Port Orchard, WA
Is there any specification information for Metric Acme Thread? I got this job from customer in other state. He said O.D. is 40mm. I got sample of plaster mold and measured which is 6mm thread. I couldn't find in 27th Machinery's Handbook. I need to machine collar that will fit this 40mm x 6mm acme thread shaft.
Charles
6mm pitch
I know there is no standard 6mm pitch for 40mm diameter as I saw in MHB. I got the plaster mold sample which my customer spreaded on his 40mm thread shaft. I measured the pitch and it IS 6. My customer said shaft is 40mm major diameter. It is easy to calculate from 30 x 6m for 40. Had to use CAD because I need it to tell me the dimension pitch diameter with three pins. This is the only way I can to make it work.
Edit. Need to make plug for checking internal thread nut on the CNC lathe
