cdnInventor
- Jul 25, 2017
For 25 years I have used the same 3:1 bevel gears and a stainless-steel flexible shaft to turn the propeller on my human-powered catamaran. Yesterday I replaced the flexible shaft assembly but today the gears became noisy, started to bind, and then seized up completely. Are these gears too worn to re-use? Could they be causing the binding? The crown gear looks o.k. to me but the pinion has a lot of wear.
Please look at the attached pictures and give me your thoughts. Thanks.
