R_W_B
- Dec 19, 2011
- Central Florida
(Backyard Auto Mechanic)
Ok I've read all the data I've found about why you should use Thread Chasers to clean threads instead of just a tap or die. They say the chaser has duller cutting edges (less angle) and is slightly less diameter than the tap and terms like less aggressive than the tap.
Here is what gets me. If I use a tap (instead of chaser) to clean my threads, it says that it will cut my threads too much causing the bolt to be slightly wobbling around in the hole. If this is the case, then why doesn't the first OEM tap cut the same exact depth and cause the same exact scenario. I don't get this ?? I mean isn't it the same thing as the tap I would be using ?
Appreciate any insight on this .
