thread pitch and size
Results 1 to 10 of 10
    Nov 2006
    Stafford VA.
    112
    Default thread pitch and size
    Hello! I am rying to figure out the thread pitch and size of a valve stem , just like on your car tire where the valve cap goes . All I have is a metric thread pitch gauge and I come up with 8mm with a .8 thread pitch . But I am not too sure if it is not an american std pitch as I do not have a gauge to cross reference.
    What do you think the size is ???
    Thanks!
    Feb 2002
    Peralta, NM USA
    5,427
    40
    327
    Quote Originally Posted by Air Chunk View Post
    Probably a Schrader valve:
    https://secure.wikimedia.org/wikiped...Schrader_valve
    Mar 2007
    On Elk Mountain, West Virginia, USA
    1,951
    723
    650
    IMHO it is .305-32, not anyone's standard AFAIK. I have made screw-on chucks for them, to go with my collection of hand tire pumps (try to have one in each vehicle)
    I'd be interested in what you're making. I recently found that Midland Metal Mfg has these chucks, but brass with short thread engagement, instead of steel and long, not as nice or probably durable as I made. It was a PITA to single-point those internal threads. Need to make some more.
    Nov 2006
    Stafford VA.
    112
    19/64 = 0.2969" 7.5406mm
    5/16 = 0.3125" 7.9375mm
    so .305 32 is not a standard tap is it ????
    Or am I missing something?
    Sep 2007
    Spanish Springs, NV
    2,367
    155
    280
    This previous forum thread might be useful to you:
    How do you measure pitch diameter on a modified buttress thread?
    Nov 2006
    Stafford VA.
    112
    Thanks for the insight and the thread link it helps.
    Jul 2002
    Maryland
    4,317
    604
    502
    If you can't find what you need i have the Tire & Rim Assoc Handbook at work. It has ALL the specs! If you need it tomorrow, PM me and I can send you a scan of Schrader Valve thread specs that will help you.
    Jul 2002
    Maryland
    4,317
    604
    502
    Thanks!
    Its most likely .305-32 as was stated by a prior poster. I got your PM, and sent you a scan of a section of the spec book back to your email.
    Ping me back by email or phone if you need addtl specs. The book is 100's of pages long, but what I sent should cover you.
    Mark
    Nov 2006
    Stafford VA.
    112
    Morsetaper2,
    Thank You !
    Nov 2008
    Israel
    988
    30
    179
    i (should) have a .305"x32 tap i bought over 20 years ago to make custom valve caps for bikes. was faintly labeled with the size and "schrader". quick google search turned this up: Engineering Supplies - a) 0.305x32 UNS HSS Ground Thread Tap Schrader valve tap
    never tried it but 5/16"x32 might be close enough.
