Boo Crew Prod
- Mar 26, 2009
- Ohio, USA
I am new to machining. I recently got my milling machine all set up and running. Now I have many projects planned. Right now I am in need of the proper tolerance to press fit bronze bushings into 14 gauge square tubing. I was told -.005 would be the best fit. I need to buy a chucking reamer and want to make sure I get the right fit.
.5610" reamer would be -.0035" to -.0045"
.5625" reamer would be -.002" to .003"
.5640" reamer would be -.0005" to 0015"
Am I correct on these?
Here is what I am working with;
Material: Bronze
Bronze Type: SAE 841 Bronze
Type: Sleeve Bearings
Certificate of Conformity: Without Certificate
For Shaft Diameter (Inside Diameter): 3/8"
Inside Diameter Tolerance: +.0005" to +.0015"
Outside Diameter: 9/16"
Outside Diameter Tolerance: +.0020" to +.0030"
Length: 1"
Length Tolerance: ±.005"
Load (P Max): 2,000
Speed (V Max): 1,200
Load at Speed (PV Max): 50,000
Any and all help would be greatly apperciated.
Ken
Material: Bronze
Length: 1"
Load (P Max): 2,000
Ken
