Tolerence for press fit bushings
Results 1 to 19 of 19
    Mar 2009
    Ohio, USA
    9
    Default Tolerence for press fit bushings
    I am new to machining. I recently got my milling machine all set up and running. Now I have many projects planned. Right now I am in need of the proper tolerance to press fit bronze bushings into 14 gauge square tubing. I was told -.005 would be the best fit. I need to buy a chucking reamer and want to make sure I get the right fit.
    .5610" reamer would be -.0035" to -.0045"
    .5625" reamer would be -.002" to .003"
    .5640" reamer would be -.0005" to 0015"
    Am I correct on these?
    Here is what I am working with;
    Material: Bronze
    Bronze Type: SAE 841 Bronze
    Type: Sleeve Bearings
    Certificate of Conformity: Without Certificate
    For Shaft Diameter (Inside Diameter): 3/8"
    Inside Diameter Tolerance: +.0005" to +.0015"
    Outside Diameter: 9/16"
    Outside Diameter Tolerance: +.0020" to +.0030"
    Length: 1"
    Length Tolerance: ±.005"
    Load (P Max): 2,000
    Speed (V Max): 1,200
    Load at Speed (PV Max): 50,000
    Any and all help would be greatly apperciated.
    Ken
    Jul 2004
    Houston, TX USA
    27,341
    What ever "tightness" you select is up to you. You possibly realize the important part is the bushing bore after it is pressed in. Tighter fits just mean this will be smaller.
    You have said nothing at all about what must fit in the bushing bore, or what size it might be.
    There have been special non cutting sizing tools made for sizing 841 bushings since machining the material just closes up the pores that let the oil out of the bushing.
    J.O.
    Mar 2009
    Ohio, USA
    9
    J.O.
    I will be using a 3/8 x 2-1/4" shoulder bolt through the bushings. The specs. for those are as follows.
    Material Type: Steel
    Steel Type: Plain Steel
    Head Style: Socket
    Head Diameter: 9/16"
    Inch Thread Size: 5/16"-18
    Shoulder Diameter: 3/8"
    Shoulder Diameter Tolerance: -.002" to -.004"
    Shoulder Length: 2-1/4"
    Shoulder Length Tolerance: ±.005"
    Tolerance: Standard
    Thread Length: 1/2"
    Thread Fit: Class 3A
    Rockwell Hardness: Minimum C32
    Thank you for your help so far.
    Jul 2004
    Houston, TX USA
    27,341
    If it were my job:
    I would have steel bushings welded in the square tube and ream them for .0005/.0010 press fit for the 841 bushings.
    Then I would SIZE (not ream) the 841 to fit the shoulder bolt as needed. These bolts are, after all, very loose tolerance on the OD and the bush may need no sizing at all.
    J.O.
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by johnoder View Post
    If it were my job:
    J.O.
    Ohhh Kaaaaaaa....... this word / procedure SIZE
    ifin it's not a reamer, or a cutting boring bar or a ball sizer...
    ZACTLY what the hell is it??
    DETAILS for us underlings on what and where we get sucha thingie??
    Dec 2004
    uk
    12,388
    3416
    5516
    Unless you specifically need the bronze for temperature range look into Igus bushings, they will live far far longer and need no resizing, just ream the hole to fit. The idea of welding a bushing into the tube aint a bad one.
    No way in hell do you need -5 thou of press fit. 1-2 thou under is going to make installation darn hard. -5 thou and your going to have difficulty getting them in. If its a oil lite material then most the oil will get squeezed out and you will have to size the bore (how ever you decide to do it)
    Some times you just need to take a good stab at things and try a few sizes to get the fits you need. Boring a few holes out might be a quick way of doing that, once you know the size that achives what you need then get a reamer!
    Dec 2008
    Berkshire County, MA
    176
    Default not enough zero's?
    Ken:
    Methinks you misplaced a zero to the left of the decimal point
    I.E. I think you want an interference of .0005
    My rule of thumb is .001 per inch of dia
    This will give you a snug fit
    Del
    PS: there's always loctite 660 if you really screwup
    Don't ask me how I know this!
    Jul 2004
    Houston, TX USA
    27,341
    a ball sizer
    That's reasonably close - think of a non cutting "broach" with each "tooth" being a portion of a "ball" a few tenths larger than its preceeding mate.
    You shove it through the bore
    You don't "get" them, you make them for the job at hand.
    J.O.
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    J.O.
    John,
    Your funnin us again... ifin there was sucha thingie... it would be made available and for sale...
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    925
    Quote Originally Posted by Gary E View Post
    John,
    There is a concept of Barrier To Entry.
    If it's easier to make than it is to purchase, then nobody makes it.
    When was the last time you bought a doorstop?
    It's illegal to buy an orgasm, you have to make them yourself.
  11. #11
    Jul 2004
    Houston, TX USA
    27,341
    Gary, I can't recall the last time I was funning anyone here.
    J.O.
  12. #12
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Interesting tool, first time I ever saw one.
  13. #13
    Jul 2009
    hope,in
    609
    27
    33
    I'd go with around .001 press fit. Also, as has been mentioned a larger diameter requires a bit more press fit. I'd also apply some loctitie to the bushing. It helps assembly as a lube and then helps keep it in place.
    Also, whatever you have for a press fit, you need to take off of the ID. That is if it is a precission fit.
    Also, I did do some parts were I made a round ball on the end of a shaft. It was a hard material and I polished it. Then I pressed it through a hole to get the hole to an exact size. I can't remeber if the part had some air metering aspect to it or not. I think I reamed, then reamed to very near size before this.
    Tom
  14. #14
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    175
    TOO MUCH press fit is one of the worst things that gets done quite often, it just ends up shaving metal off an other bad things, some folks think "if some is good, more is better".
    When the hole gets accidentally bored so the bushing slips in, then gets cleaned up well with lacquer thinner, roughed a bit with some 80 grit, then glued in with red loctite the end result is a lot better than when somebody decided .003" was the proper press fit for a drill bushing liner :-).
  15. #15
    Jun 2010
    milton freewater oregon
    2,038
    3809
    1640
    The rule of thumb as far as I know was .001 per inch of OD bore.
    If you press a 5.005 bushing into a 5.000 bore you best bore the bushings ID to 5.006"+
    Never make a bushing too tight, it will shear off the press fit and just fall out later..
  16. #16
    Aug 2003
    Eureka, CA, USA
    1,650
    353
    262
    The old Boston Gear catalogs (the "pocket-sized model" from where John might have extracted that sizing tool sketch) contained much useful information about installing and running oilite bearings as well as other helpful information about shafting and gearing.
    I'm not sure that the new catalogs include the same stuff. (If not, too bad since the pocket-size edition morphed into a collection that now takes up over six inches of room on my bookshelf and I hardly ever look at them !)
  17. #17
    Aug 2005
    Central Texas
    560
    8
    Machinery's Handbook has several pages of info on press fits and running clearances. As a newbie to machining, you might want to pick up a copy - it's been in print for many years and the old editions are just as good as a new one.
  18. #18
    Mar 2007
    On Elk Mountain, West Virginia, USA
    1,941
    712
    644
    I think johnoder's idea about welding in a steel bushing first is essential.
    If you put a bronze or plastic (Igus) bush into a transverse hole in a tube, it will be supported only by the tube wall. Most of the length of the bushing being unsupported will deflect away from the load and the resulting actual bearing area will be very small. It will wear out/pound out very quickly.
  19. #19
    Jan 2008
    NY
    254
    26
    The press fit on a .500 OD valve guide for a 350 Chevy is .002”. Perhaps this is to allow for heat expansion. On an iron liner for repairing an engine block it is .0005” per inch of bore. So a sleeve to press in a 4.000” hole you would have .002” press fit. In both cases it is typical to hone the ID after installation for final sizing.
    Just some press fit tidbits from my world.
  20. Likes S_W_Bausch liked this post
