Have run into a slight problem with the old DSG, have only got an inch from centre to top of compound so not much room for a respectably sized QCTP. I acquired a Dickson that takes a 3/4 shank but theres not enough room, even with a 1/2 shank tool its just about coming off the adjusters. I really dont want to be cutting chunks out of the compound or the Dickson.
Im thinking of using the clamp that came with the machine and making a block (possibly one piece) to register a 1 inch tool on. The compound could be left on Z for most work, could have various tools to cut left an right / chamfer / groove an parting etc. Changing tools should be pretty much as quick as a QCTP, they should be on centre ish, aligned and repeatable.
The top of the compound only has a hole for the centre bolt and two counter bores for the two front gib bolts, no other features to register four way that might have originally come with the machine.
Something along these lines. The clamp would come down over the lot, possibly with something to push it up and out the way when changing a tool.
