rhpope
- Dec 21, 2005
- Durham, NC
I'm new to surface grinding. I think what I understand as for what types of stones to have on hand are 46 grit H, I, and J for most general/universal use.
I think I understand that:
H is for hardened steels, would this be something like HSS such as HSS cutters?
I is for softer steels, would this be for mild steels such as 10XX series steels?
J is for, not sure???
What type of wheel would you use for cast iron, non-hardened and for hardened???
Also, of the wheels, you have a selection of different colors/types of stone such as White Alum Oxide, Pink Alum Oxide, AZ, 32A Alum Oxide, Cermic Grain, and probably some more that I don't know about. The white and the 32A may be the same, but I am not sure.
What is the best color/type of stone for universal grinding on mild steel, hardened steel such as HSS, and cast iron? Maybe there is no such thing as a universal for all these different ones
What would you use for grinding carbide?
What about stainless steels?
What about something like D2 tool steels for forging dies?
What would you use for grinding say 4340 or 5140 steels?
When would you use 60, 80, 100, or 120 grit stones?
Roger
Roger
