If I asked someone to draw up a 48 tooth sprocket for a 530 chain, would anyone do it? I'm asking btw.
Reason is, I just cut one using the same teeth I used on another gear and it isn't fitting. Not sure what I did wrong but I wanna see if I can salvage the gear by cutting a little more off of it or if it's just too far gone.
So I need a 48 tooth gear with a 9.87 OD and 9.11 ID for a 530 chain. I'm not giving any values for the 530 because I think that's where I screwed up and hoping someone here knows more about chains than I do (which is pretty easy to do!).
