There are several different models of Wilton 20" drill press on eBay now. Several of them say they have 3MT spindles, and several just don't say, but probably do. A 20" drill press of high quality Swedish make will not have only a male Jacobs taper on the end of the spindle. A Morse taper spindle is always a female, to allow drills and chuck arbors to be inserted.
The 3MT spindle might extend below the bottom spindle bearing and have a visible extractor slot. But I have seen spindles where the 3MT is flush with the retainer for the bottom bearing, with the taper entirely enclosed in the quill. On those, you feed the quill down out of the head all the way. Then you see a slot in the quill that will line up with the extractor slot in the spindle if you rotate the spindle properly. Then you can use the wedge in the usual way to extract the drill or chuck arbor.
Larry
