I'm having a problem with tir and taper when turning 4140 prehard hrc 29...
Mori MS850 5hp machine, 1800rpm (max rpm), .006-.008 ipr, cnmg 432 inserts rp/fn/ff, kennemetal 3/4 holder at various lead angles, in aloris post.
Round bar 0.669 sticking 1.250 out of the chuck turned down to 0.500, testing doc ranges between .030 to .080. Any of the doc produces mirror finish.
The problem is...
I'm getting a taper of roughly .001 per .500 length and tir of about .0015 down the entire bar.
With a 2.000 tube of 6061 or 1018 sticking 8 inches out of the chuck, using same speeds as above, I get no measurable taper or runout...
Not sure if I'm using the wrong tooling for the hardened stuff, I have a job coming up with the same size bar stock in 4340 @ hrc 40 and I fear even worse results.
Maybe there is something else causing the problem?
Any help would be greatly appreciated!
The problem is...
