Son of Sam
- Oct 11, 2014
- South Jersey, USA
Often we encounter square shafts that are turned round on ends to fit bearings. If they are 1-1/4" square of less this is no problem because we put them through the headstock with a 4-jaw. The problem comes with anything larger. 1-1/2, 2" are very common and I have even done up to 3-1/2". Shafts range from 24" up to 84". This is what I have done so far with mixed or limited success.
1. Milled a square into a round boss with a couple set screws and held that in the steady rest.- This allows for end work to be done such as a tapped hole. Chatter is an issue as well as the ability to take any decent size cuts.
2. Milled the face and indicated the center in mill, center drilled the end. Works decent but chatter is still a huge issue.
I am wondering if there is a so called "Proper" way to do this, or has someone found something that works better than what I am doing.
