I guess the controversy can be summed up: If you got a $400 test bar use it. If not, a $12 hunk of pipe and a half hour of basic machine work will make a gage that will supply most of the same data.
If you leave your skill and brains at the shop door the best tooling is the world will be wasted on you. BUT: if you think your problems though and keep your mind open to your inner machinist you can finesse an absence of world class tooling and still do the job, determine the error, solve the problem, be a friend to man etc.
HEAT,(yes Demon73) and of corse to save time, more than tool wear(although good to reduce that as a parameter). as the part heats up, as it will from the cut, even if its a light cut (less so with coolant, obviously), and also from the friction of rotating on a center, the test bar expands in diameter, so a bar cut end to end, all other things being ideal, one would expect to have a taper upon cooling.
Something else not mentioned, ..yes you can have a $$$$$$$$$$$$ test bar, but you are measuring with that, whereas a turned test bar gives the result for actually cutting .........which are two completely different animals.
I firmly believe in the test as being an accurate means of checking, it has come straight from a South Bend set up manual. However I am definitely not counting out the test bar, as it is just that. Precision level is an excellent start point and the collar test should prove as a second setup method.
You are 100% correct, it definitely does not determine the cause. Thanks for your input!
Notice
