I did do a hole pattern in the end of some very long part with an angle head set at 90 degrees. What a PITA it was basically hand coding that. I find it tough to use CAM because none of the clearance moves are in Z. I maybe could have fooled around with the post I was using and made something work, but it was probably more work to test that, than to just single step my program in air cut mode first.
