dhepler
- Apr 14, 2009
- cobb county Ga
I have used an edge finder a lot but have never understood how to use and the applications for the pointed end of an edge finder (not a common wiggler)
So how does it work?
the conical, and for that matter the cylindrical end as well, can be used with the machine off and feel for when there is alignment with the body. Accuracy within a thou or two. Use the conical end in a centre punch mark, centre drilled hole, spotted hole, bore, pilot hole....you get the idea. If its needs greater accuracy use an indicator directly or with a wiggler
That is how I have used the conical finder too but thought it was pretty archaic...I have a wiggler but haven't used it because again, I have no real idea how it works or why it might be more accurate than the funky conical center finder.
Stuart
I use the pointy end when positioning a spindle axis over a scribed line, or, more usually, over the intersection of a scribed-line pair.
To center the pointy tip on the spindle axis, I fire up the spindle and then touch the side of the spinning cone with a steel rule, pencil, or tip of a finger until it runs true. Then, after stopping the spindle, I watch thisaway -- ALONG the scribed line -- while moving the work (or spindle) thataway -- perpendicular to the scribed line, until the tip is centered over the line. Then, if centering a scribed-line intersection, I watch thataway -- ALONG the OTHER scribed line -- while moving the work (or spindle) thisaway -- perpendicular to the line I'm watching -- until the second scribed-line is centered.
John,
I have a piece of 1/2" drill rod that I've ground to a sharp point. I do the same routine you described to align the quill above a line or punch point...but I don't have all the monkey motion of the little moveable tip to deal with. What's the difference? Why the moveable conical point?
That seems perfectly reasonable but I can't help but wonder if somebody at the Acme Edge Finder Company said, "man, how can we charge a higher price for these things?" and the response was, "let's put a pointed tip on the other end and see if anybody's willing to pay more. We'll call it the deluxe version." Because everybody knows how the edge finder part works, you'd just expect some similar clever use of the pointed end, but nooooo... you just stick it in a divot and slide the table around until it's centered.
My sentiments exactly.......
Stuart
Notice
