Wandering holes?
Results 1 to 11 of 11
    Aug 2016
    Colorado
    25
    8
    Default Wandering holes?
    Hey guys. I need some insight on how to make some holes. The project needs a block thats split along the x axis, to bolt around a shaft thats on the z axis. I am planning on clamping both together and drilling through where the seam Would be. Would the bit tend to wander along that seam?? I'm also considering using a ball end mill with each half turned 90° to make the hole. What would you guys do?
    Thanks a bunch!
    Mike
    Jan 2014
    Temecula, Ca
    1,573
    677
    2117
    sonds straight forward, but can you post a picture? Material?
    Sep 2008
    754
    391
    401
    Quote Originally Posted by MikeColorado View Post
    Thanks a bunch!
    Mike
    I drill and ream thru 2 blocks clamped together all the time, never had a problem, one benefit is you will not have long pieces of swarfe generated while drilling
    Aug 2016
    Colorado
    25
    8
    Pretty simple part, and not sure of the material yet. Most likely 7075, but maybe titanium in the future.
    Jan 2014
    Temecula, Ca
    1,573
    677
    2117
    if you've got them clamped together, just spot drill and drill them and I don't see where you'll have any problem.
    Jan 2005
    CANADA
    Saskatchewan
    8,983
    964
    2796
    I don't think the design is that good from the view of clamping parallel to a parting line: the bolt and nut may not actually capture both halves.
    Aug 2016
    Colorado
    25
    8
    it will be clamping along the y axis in this case, or perpendicular to the parting line. the screws joining the halves will be running through the material between the recessed area and the outside diameter of the vertical holes. i appreciate the insight fellas, sounds like ill be fine clamping them in the vise and gettin after it! thanks all!block3a.jpg
    Jul 2003
    savannah, jaw-ja
    1,449
    751
    276
    maybe I am missing something but - if you clamp those parts together in the vise, and drill/ream down the split, you are going to get a hole exactly the size you ream. Obviously. If it is to clamp and object the size of your reamer, it won't, without either skinning a bit off both inside faces after you drill/ream, or putting a small spacer in the seam before you drill/ream...
    If it is to clamp an object bigger than your reamer, there's other issues..
    Jan 2007
    Norfolk, UK
    16,103
    11635
    11056
    If in situations like that, I'm in any doubt I drill say 1/32 - 1/16 US then true the hole with a 3 fl EM ....especially if I've packing between the 2 halves to make them clamps as opposed to a slide fit.
  10. Likes eKretz liked this post
  11. #10
    Feb 2010
    ch
    1,829
    170
    231
    i like to bolt the halves together. then they wont move and you can take them out and put them back in.
  12. Likes Limy Sami liked this post
  13. #11
    Jan 2007
    Norfolk, UK
    16,103
    11635
    11056
    Quote Originally Posted by dian View Post
    True, but you can still be ''unlucky'' and have a drill wander slightly because of the joint, .......BTDT carry the scars.
    Just saying
  14. Likes digger doug, Matt_Maguire liked this post
