B Sutherland
- Jan 26, 2006
- Ontario, Canada
I have been recently cleaning up an old Ward 2DS capstan lathe and am currently going over the collet chuck. There is a rotatable outer sleeve that actuates the balls that closes the collets and there is approx 1/16" of free play in this sleeve. When disassembled there is a ball thrust bearing on one end and a bronze ring on the other end. To me I would think that there shouldn't be any end play in this assembly but before I make a new bronze ring I thought I would see if anyone here is familiar with this unit.
On a secondary note I've taken almost everything apart on this lathe because whoever owned it before thought that all the oil nipples were grease nipples and everything is plugged up with old solidified grease. What a mess. Things sure do work smoother with the oil where it's supposed to be.
