Warner and Swasey chuck 1605C
Community On The Web
Results 1 to 13 of 13
    Dec 2005
    Langley, B.C.
    92
    Default Warner and Swasey chuck 1605C
    I have a W&S 1605C chuck and I can find no online reference to 1605C. What is it? Spindle type?
    I want to mount it onto a D1-6 backing plate, the right one if I can find it. Does someone make adapters for A,B American Standard to D camlock?
    Jul 2004
    Houston, TX USA
    26,077
    Nearest in their book is M-1608 which is a 12" four jaw with 8" A type spindle nose
    W&S OFTEN have A type spindle noses
  3. Likes JRIowa liked this post
    May 2003
    Iowa
    9,450
    2574
    3291
    I'd have to look at that chuck very hard before spending any money on it. AFAIK, W&S stopped making chucks over 40 years ago. Don't get me wrong, they made very good chucks, but yours was probably mounted on a turret lathe and had the crap beat out of it.
    JR
  5. Likes Bill in PA liked this post
  6. #4
    Dec 2005
    Langley, B.C.
    92
    Has ACME T. L. stamped in it. I will disassemble and evaluate before I go further. If you wanted to see pictures what would you like to see?
    Its not like I don't have a 3 jaw chuck but its Chicom and on a Monarch, well that just doesn't feel right. This W&S seems much more substantial and has T&G reversible jaws, I have used it before on an old lathe with a screw-on spindle but have now upgraded to this Monarch lathe so hence the dilemma.
    Thx all
  7. #5
    Oct 2005
    erie,pa
    6,177
    12684
    2730
    Quote Originally Posted by weedy64 View Post
    Maybe more important, what is your intended usage of this chuck ? and what level of accuracy do you need ?
  8. Likes JRIowa liked this post
  9. #6
    Dec 2005
    Langley, B.C.
    92
    The lathe is 28" x 144". I turn (rough) 18" chilled iron rolls (3500lbs max) with the lathe, so it would hold a roll stub shaft/axle 2-5"dia, other end is live centered in tail-stock. I finished corrugating them on an old planer. Smaller rolls I turn and then thread\groove the length 8"x55" or so at 8-10tpi (double start 5. I can live with .002-.003 TIR, obviously the less the better. If I can grip adequately with the 3 Jaw then I don't have to change chucks as often. The 4 Jaw is just that much bigger to deal with on this lathe. A jib might be nice. I have a 3T rail but its lying on the ground so far. I currently use a forklift for loading work pieces but its a bit cumbersome for chuck work.
    My previous lathe was smaller, old(babbit) and worn out and so the roll size was limited to 12". I used the 4jaw in this case, it never came with a 3jaw until the W&S one was acquired. I never ran rolls with it the (3jaw) I don't think and if so they were limited to 1200#.
    The new to me lathe allows me to do all of the sizes I deal with except the 24"ers.
  10. #7
    Oct 2005
    erie,pa
    6,177
    12684
    2730
    So this is a powerchuck with the powerwrench attached to the headstock, comes in from the
    back with a jaw coupling to engage the pinions ?
    Or is this a hydraulic/air cylinder type ?
    I think .002 T.I.R. is gonna be hard to hold.
  11. #8
    Dec 2005
    Langley, B.C.
    92
    No its a manual chuck.
    Maybe my TIR requirement is out to lunch.
    These rolls are for feed processing so their surface wears and needs truing. I indicate the shafts when I setup and cut the wearing surface true. They weigh enough that I think it is easier on their bearings if they are concentric. I don't recall their operating rpm but I think its in the 4-600rpm range
  12. #9
    Jul 2004
    Houston, TX USA
    26,077
    Which means Acme Turret Lathe - a make eventually owned by L&S.
    Smallest will have 8" Type A and largest will have 11" Type A spindle noses
    D1-6" on a 28" lathe sounds wimpy. Has the lathe been raised?
  13. #10
    Dec 2005
    Langley, B.C.
    92
    It does seem wimpy to me too, but it is what it is. Its a 612 2516-19 x 144, Yes it has a factory raised compound for sure, about 1-1/4" . I can't really tell looking at the headstock/tailstock it all looks fairly large. Its is the only Monarch of this type Ive ever had my hands on. It was used in a plywood plant to peel rubber off of large rolls etc, it was dirty but quiet when I bought it. The mill closed and dispersed equipment, the onsite maintenance staff said it never worked very hard at that plant. So the D1-6 wasn't a factor. Previous use - who knows, paperwork says it always belonged to Georgia Pacific forestry..
    here is a very similar unit with a lot of new paint!
    Page Not Found - Your Ultimate Source For Buying and Selling Quality Metalworking, Woodworking and Industrial Machinery
    says Page Not Found but link currently works for me
  14. #11
    Jul 2004
    Houston, TX USA
    26,077
    Whatever - there it is. Thumbnail will give info and 8" and 11" A type. And what ever that is, your D1-6" backplate / adapter will have to accommodate whatever bolt holes are in the chuck. Better if chuck is A-11" as it will be easier to get the chuck bolts to miss the D1-6" details - though thicker back plates can help. Second thumbnail has D1-6" info
    If it turns out you can't read these we can try emailing them if you want to private message me that address
  15. #12
    Dec 2005
    Langley, B.C.
    92
    Thanks I can read them.
    Im sure its not an 11" as the chuck is ~10", I think its an 8" but maybe a 6" A type. I will look it over when Im in the shop again.
  16. #13
    Dec 2005
    Langley, B.C.
    92
    It will make a much better fixture for the mill than to try and adapt the A8 to D1-6 spindle.
