Warner and Swasey lathes?
Results 1 to 15 of 15
    Jun 2006
    N Idaho
    813
    12
    Default Warner and Swasey lathes?
    What can you guys tell me about these?
    The price?
    Can they be used "conventionally" IE without the turret?
    Parts availability?
    Oct 2004
    Elyria Ohio
    1,609
    2761
    556
    Default warner and swasey
    They are cheap, robust, last forever and can be used conventionally. Make sure you know what you are getting though. Many of them were ordered with the collet closer only and so don't expect to automatically get a chuck with it. For a #3 you can probably find them for around $1000. I have a #6 Bardons & Oliver I may be willing to get rid of. 20 hp machine. It's out in a storage building right now but the last time I ran it ran fine. If you're interested let me know and I will go start it up. It has a three jaw chuck (about 18") and I think I have a four jaw for it. It shifts good and the feed on the carriage and cross slide were fine. I remember having to tighten the clutch nut on the hex turret feed to push big drills and then I would back it off for smaller tools because I could feel the teeth of the clutch faintly making contact. Anyhow, Bardons & Oliver is still in business and W&S is not.
    Regards,
    Joe
    Jun 2003
    Thomasville, GA
    1,562
    6
    The one at the school has no topslide, which really limits its usefulness. Otherwise, it's a smooth-running horse of a machine.
    Roger
    Jun 2003
    Mebane North Carolina USA
    6,205
    51
    1660
    W+S eventually became part of giddings and lewis.
    They will sell you parts I believe though it does not matter. As with all the old makers the parts are priced such that you can buy another used machine cheaper.
    Sep 2006
    New York
    66
    Strong simple machine to work on and, reasonably priced to boot. I gave 300 for a #4 and have another 500 or so into having the moror rewound and tooling specific for it. (spent more on boring bars, indexable tool holders and what not but I can use them on other machines so I dont really consider them to be a cost specific to the W&S)
    I use my #4 for almost everything, I keep a boring bar in one slide tool and another bar in the oposite set for cutting OD's then a couple drill chucks and a center in the other faces. In the square turret I keep 4 tool holders so I can switch between facing, left and right turning and chamfering with the partoff tool in the rear tool post. For me I'd rather keep a general st up that I can taylot to each part than stop after every operation to change tooling for the next operation.
    I'm just a hobbyist, I make parts for my old tractors and repair worn out parts that I can't reasonably make. I don't know how I got along without the turret lathe, it sure has made my life alot easier. The only problem is 1 warner swassey tends to get a little lonley in a shop with a couple of south bends, so I may have to find a 1A or a well tooled #5 to keep it company in the future.
  6. Likes lathefan liked this post
    Dec 2007
    Monmouth, OR
    368
    32
    27
    Default work horse
    I have a #5 from around 1950. It is old but very strong. Will take a larger DOC than I have the balls to take. Picked it up for $900 fully tooled with a couple boxes of big ass inserts and a power chuck. Made the cost of the lathe back on the first couple of parts on the first job I ran on it. No leed screw so no threading but a die head works very good. Have had no regrets about buying it even though its a dinosaur. Highly repeatable.
  8. Likes lathefan liked this post
  9. #7
    Sep 2005
    il.
    6,549
    29
    1172
    W&S turrets won WWII
    there solid if you get a good one (ain't they all)
    you can thread with die heads (i got a couple)
    nothin nicer than setting up the feed kick out when your boring or turning off a couple inches of material
    my #3 you can only get about 18" or so between centers
    there mostly american standard A *-* mounts so if it has a collet system you can easly find a chuck to swap in
  10. Likes lathefan liked this post
  11. #8
    May 2003
    Iowa
    9,837
    3021
    3682
    You guys just keep talking about them little ones!
    Put an "A" after the number and now we're talking LATHE.
    Price - depends on size, shape, and tooling. Scrap metal to $100K and everthing in between.
    Parts - If you've got money, MAG group. If not, Gahr machine.
    2 years ago, I bought a 5L Gisholt for parts. Took the 36" 4-jaw, the treading box, and the compound (yep, on a turret) and scrapped the rest.
    JR
  12. #9
    Sep 2005
    il.
    6,549
    29
    1172
    watched eric bruce (you might know that name jr)
    stand at the wheel of some awsome cuts on a bomber class 2a we had
    back in the other century
    guy was made of stone when it came to throwin chips
    watched him spin a 1 foot cube into a quad punkin
    cool shit
  13. Likes lathefan liked this post
  14. #10
    Jan 2005
    Victoria, Texas, USA
    3,532
    1521
    747
    Default 4A Warner's
    Wipin boy, youre something else!!
    I remenber Dad gripin about the 4A's, having to tear into the aprons on both the cross slides and cross sliding turret. What a night mare! Anytime we went to Drilco, they always had one or two aprons tore down repairing them. But what MEAN cutting machines they were! I don't know of a CNC out there that will compare, or compete to a 4A or 5A today!!!!
    By the way, I wound up scrapping out that No. 5 given to me. Too much cost to get running when I can buy one running for a cheaper price.
    Ken S.
  15. #11
    Jun 2006
    N Idaho
    813
    12
    Well, guys, the "party's over." I called, left a message. This morning, the $600.00 each price (he has three) turned into a "misprint" and now they're $2000.00.
    My brother in law is a machinist, and told me these are big three phase machines.
  16. #12
    Sep 2006
    New York
    66
    Quote Originally Posted by 440roadrunner View Post
    Well keep looking, you'll find one in that 600 range eventully, I'f I had to venture a guess 2000 would be for a very well tooled round head or a newer square head machine, while tooling is everythin with these machines 2000 would still be a little steep for my budget at this point.
    As for being three phase I run my #4 on a static converter on our single phase power, works like a champ. The size is also an advantage if you have room for it, they're just plain ridged, I've done interupted cuts on mine that I wouldnt dream of trying on any of my other machines. Not to mention taking a .100 off the daiameter in a single pass in mild steel dosn't even make her work. .030 is a heavy cut on my smaller machine, on the W&S thats what I leave for the finishing pass.
  17. Likes lathefan liked this post
  18. #13
    Feb 2005
    Minneapolis, MN, USA
    540
    33
    15
    Noticed that there is a guy in Becker MN selling a #5 on Craigslist. Might be a little farther away than you'd like though!
    --Larry
  19. #14
    May 2003
    Iowa
    9,837
    3021
    3682
    On the smaller W&S turrets, the cost has a lot to do with it's a bar machine or a chucker. Chuckers are cheaper! You can turn a bar machine into a chucker real easy, but it's very expensive to do the reverse. I've seen places get rid of old bar machines and keep the master collet and all the pads.
    JR
  20. #15
    Jun 2003
    6,205
    51
    1660
    Of course its three phase. Ant machine worth a damn is 3 phase
