Way to change output shaft rotation.
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Nov 2005
    Saskatchewan, Canada
    100
    8
    Post
    Have a request to do a project that requires changing the direction of rotation of an output shaft of a garden tractor. If you can picture the shaft coming out of the front end of a garden tractor trans.Customer wants shaft to extend out the front of the tractor. This part is easy, But the implement requires the opposite rotation. Have a picture in my mind of a small gearbox with 2 spurgears to change rotation.Horsepower requirements are about 25 horespower.This would be lightweight & have gearlube inside.Also have an idea of 2 sprockets & using the tightener sprocket with bearings on the front & back side of plates to support shafts.I think gearbox would be nicer if price is reasonable. Any ideas & suppliers keeping in mind we are in Canada would be greatly appreciated.Thanks for now.
    May 2005
    Republic of Arizonia
    1,435
    375
    Post
    Crossed belt
    Sep 2005
    South Carolina USA
    4,498
    2154
    1304
    Post
    Crossed belt
    I was going to suggest the Crossed Belt, also.. But was afraid I might be thought of as a Simpleton that was raised on a farm..
    <<< Raised on a farm.. [img]smile.gif[/img]
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1003
    Post
    If you go the gear route, I'd try to go with helicals, despite some end thrust, to reduce noise/whine. I'd go with tapered roller bearings and an oil fill and call it a good day. Shaft seals would be necessary plus a good protection shield would also help to keep the heavy chunks out.
    I'm also trying to recall if a planetary set can reverse rotation...might be able to find horsepower-validated components in a (good, but) scrapped automotive transmission.
    Nov 2005
    100
    8
    Post
    Yes I did think of this but he wants to run a grain conveyor & I don't think this will give a positive enough drive. Any more ideas.
    Nov 2005
    100
    8
    Post
    I like the path you are on Matt. Does someone manufacture a small gearbox like that or do I have to manufacture it.Thanks for the input by the way.
    Apr 2004
    Modesto, CA USA
    5,699
    841
    Post
    I am thinking a motercyle gearbox has severaL forward and at least one reverse gear.
    Bill D.
    Nov 2005
    100
    8
    Post
    Also Matt I don't think we need the helical gear route as their will be no end thrust at all, just straight old motion transfer.
    Jul 2006
    west u.s.
    193
    Post
    Something you may wish to think about would be the use of a PTO gear box.
    They can be purchased in right or left drives, be
    disengaged when not in use and gear reductions can
    be sized. At best perhaps the only thing you would need to add would be a base plate for mounting.
    Just an idea that may help,
    Patch
    Oct 2005
    Ont. Canada
    659
    Post
    Kingston;
    Check the "Drive Line section" at Princess Auto.
    There is one in Regina, and in Saskatoon. They
    are very good at carrying PTO,Tractor, and trailer
    parts. Or check out their website www.princessauto
    .com.
    I am in no way associated with Princess Auto or
    its affiliates.
    Jamie
  11. #11
    Oct 2004
    blackstone. ma
    324
    Post
    turn machine 180 deg.
  12. #12
    Apr 2004
    Modesto, CA USA
    5,699
    841
    Post
    not sure if this will work or not. use a rear drive differential from a car. lock the drive shaft so it can't turn. spin one wheel the other rotates in the opiste direction. Wil lthis actually transfer any force/ no idea at all.
    Bill D.
  13. #13
    Jan 2007
    New Hampshire USA
    700
    25
    Post
    What patch said.
    PTO gear box
    Or, how about a " Parallel Shaft " gear box/speed reducer ?
    From Boston Gear or Graingers or similar.
    Just slip it on.
    Maybe $200-300US New I'm guessing.
    Good luck.
    SM
  14. #14
    May 2002
    Auckland, New Zealand
    4,390
    1320
    410
    Post
    Would a right angle drive be any advantage? You can get inexpensive, robust agricultural bevel gearboxes, they offer a choice or rotation direction depending which side the output bevel is fitted.
    We used to use Comer (made in Italy), they were excellent units, the one we used was the L5A from memory, cast iron, it handled 15hp @ 540 rpm. There also an aluminium version, the L25A. There was a choice of shaft type (either 25mm plain, keyed, or splined) and 1:1 and other ratios. Could also get it with double output shaft. The housings have tapped holes for mounting. Also larger models available.
    These gearboxes were inexpensive, we paid around NZ$100, but thats a few years back, and we bought them as OEM buyers.
    Not a very easy website, nor does it show Canadian distributors, but you could try an e-mail for local distributors?
    http://www.comerindustries.com/eng/area3/index.htm
  15. #15
    Oct 2005
    Putnam CT USA
    570
    163
    23
    Post
    We had a saw rig when I was at home and the cross belt worked just fine.
    Certainly the 'cost' justifies the attempt. Flip side would be to turn the tractot 180 degrees.
  16. #16
    Nov 2005
    100
    8
    Post
    SlicerMan: I think we might be on the same page with a parallel shaft setup but wasn't sure of the proper name. I am thinking of an aluminum case but not sure where to access one in Canada.Thanks everyone for the ideas so far.
  17. #17
    Jan 2012
    n.w. ohio
    Default reverse shaft direction
    I noticed a post from 2007 in regards to changing the shaft rotation direction on a small lawn tractor. I purchased a 40 in. snow blower and mounted it on the front of my 618 grasshopper mower. Everything worked out perfect except for the shaft rotation. It never crossed my mind about the shaft rotation. Now I have considerable time and money invested and wanted to ask how you resolved your problem . I would like to find some type of in line device, maybe a tubular unit that uses some type of planitary gears to change the saft direction I don't have a lot of space to work with.Any input would be very much appreciated thanks Dave
  18. #18
    Jan 2012
    New Mexico USA
    23
    Default Shaft Rotation
    Have you looked at Surplus Center in Lincoln Nebraska?
  19. #19
    Dec 2004
    uk
    12,487
    3493
    5603
    Sharpen opposite edges on the attachment?
  20. #20
    Mar 2009
    Eureka, CA
    3,325
    584
    1027
    Quote Originally Posted by adama View Post
    How do you sharpen a 'grain conveyor'?
    Stuart
